A slightly rough idle is pretty much the norm for most 7.3L's. A lot of times it has to do with the cam position sensor. Try replacing that to see if the issue fixes or changes. Use only Ford or International cam sensors.
The main three things that cause a loss of power are; low boost, weak HPOP, or worn injectors. Start with checking to see if you have any boost leaks.
That list of mods is a good place to start. We can get you setup with all of it if you are interested. Let me know if you have any questions.
