1 - 4 of 4 Posts
Ummm.... you mean when the truck is hot and cycling coolant the level is lower than when the truck has cooled off, then the coolant level is higher again???
Correct, anyone else chime in... however mine does this and it seems normal to me.... If you take the cap off slowly on mine when it is still hot the reservor fills itself back up. Make sure he also has a max coolant level at the point where it says min.... you do not want to fill it to the max line!!!
1 - 4 of 4 Posts
