1 - 13 of 13 Posts
Dropped the truck off at PowerStrokeMagic in Houston. I feel like a parent with a missing child. I'm trusting TJ with my baby!! lol
He'll be doing:
Full Headstud Job
EGR Delete
Oil Cooler
Updated Turbo Feed Line
Updated Turbo Drain Tube
Updated STC
6.4 Banjo Bolts
MBRP 4" TB Exhaust
Water Pump (probably)
Its been a long time coming, the ECT/EOT Delta was creeping up, so I decided it was time. I'm looking forward to getting it back.
Discussion Starter · #2 ·
No turning back now!!!
Talked to TJ this morning. Cab is back on!!
Old exhaust out.....
MBRP 4" TB Exhaust going in!!!
I'm headed out there in the morning to pick it up!!
Discussion Starter · #6 ·
Picked the truck up. TJ and the guys at PSM did a jam up job!! Loading SRL+ and heading home!!!
damn that was a fast head stud job! did they check the heads and what not. i dont even know a machine shop that could get the work done that fast!
Discussion Starter · #9 ·
Yes, heads checked out fine.
I would say it was well worth it. Here is when I took it over (crappy cell pic):
And here is the ride home today, (same speed, same road) MUCH better!!:
dang! kudos to that machine shop! mine normally take me a week or so when i do one. its not hard to do really if you had the heads there i could do it in the same amount of time but to ship them out and get it back and have it all done that fast is amazing!
I know exactly how you feel. I typically only drive my truck on weekends, but I'm still uncomfortable when it's not parked in my driveway. It's my baby.
Discussion Starter · #13 ·
Had some more pics I didn't get a chance to post.
Couple of cab-off pics:
Up-Pipe blocked off:
STC fitting update:
6.4 Banjo Bolts:
Had a cracked coolant reservoir (hard to see):
Bad upper radiator hose:
Replaced the boots:
Bad heater control valve:
MBRP 4" exhaust with polished tip:
1 - 13 of 13 Posts
