1 - 3 of 3 Posts
So I have been stumped all weekend on my 05 stroke. New alt, new batts? Wondering if it could be the FICM. So the batts will show 13.5 as soon as I turn the key The FICM comes on and the batt volts drop to 12.1, and when I crank it the volts drop to 10.2 and that barely gets the starter to click. I've got fully charged batteries and even hooked my wife's truck up with jumper cables. I tested the FICM's volts( 4pin) and it shows 48.2
Should the volts drop that low by just turning the ign on, all acc or off. Need help!
Thanks
Discussion Starter #2
Electrical issue have always been my weak link.
So I did a continuity check on the pos cable on top
The radiator. It is showing -2
If this helps someone help me out.
1 - 3 of 3 Posts
