1 - 18 of 18 Posts
Thinkin about sellin the TS re-speed I got. I installed it to get out of a speeding ticket. It will adjust the speed if running larger tires or gears. Will fit Any 99-06 Superduty. Heres some info on what it does,
-Speedometer Recalibration & Speed Limiter Removal Unit.
-Recalibrates tire size and/or gear ratio for accurate speed readings to gain precise engine performance and speedometer display.
-The RESPEED can turn off the speed limiter or set the maximum speed the computer sees for optimum engine performance
-Applications available for Diesel & Gas!
Askin $150 shipped.
Yes it does fit the OBS, you have to hook it into the Red/Pink wire behind the speedo. It will take the speed limit off. Let me know if you want it, your the only one so far.
Local *******
is this gone?
Local *******
take paypal?
Local *******
you have a payment!
K thank you I will send it tomorrow but it won't leave town till thursday. The town i live in is small ( real small) so the mail is everyother day here. Thanks Jon
Local *******
got it bud thanks! best option im guessing is pull the fender liner? grey/blk wire in the abs group under driver side battery?
Yeah the wire loom had some pink tape around it. There is only one grey/black wire in that loom. Good luck.
owner/president
You don't have to pull the liner all the way out,just drop the front,or trace the loom back to the top of the fender.
got fuel?
Stop injectors from shutting the motor down at 114mph. By eliminating the top speed.
< Can I drive?!
our trucks go 114?! they have speed limiters?! haha the new things i learn :doh:
got fuel?
Yea, zanes race truck gained 8mph after one of these installed, in the 1/4.
Discussion Starter #18
It also change the speedo for larger tires. Since the VSS goes straight into the PCM. It was said to help with my shifts with 38's. It did but not what I was looking for.
1 - 18 of 18 Posts
