That can short out PCM power and cause a no-crank from low or no voltage. Might also blow PCM fuse F2.22. Also - who would want to run without any cooling?
What are my options for repair?That can short out PCM power and cause a no-crank. Also - who would want to run without any cooling?
Fan Clutch connector - female (clutch side) Definitely WPT-1045 fits all MY's. 1U2Z-14S411-AHC is also correct
I’m considering the 7.3 fan clutch and taping off the wires for the electric clutch because it chewed off so much wire I can’t get a wire connector in there, let alone 6 wire connectors.
Fan Clutch connector - male (engine side)
WPT-1136. also 1U2Z-14S411-AKB
I believe that the link below is one of the ones described above.
1U2Z-14S411-AKB 1U2Z14S411AKB Genuine Ford Part
Ford part # 1U2Z-14S411-AKB 1U2Z14S411AKB, Base part # 14S411, $38.08 online at FordPartsGiant.com. Wholesale-priced and fast-delivered Ford parts Wire Assembly.www.fordpartsgiant.com
There is an attachment point on the Stator that keeps the harness out of the way of the blades. If the stator is gone, you need to make your own "protection system". I just drilled a hole and added a grommet.
Here is mine
You may need a new fan clutch.
To add to your oil dilution statement: rolling coal is excess unburnt fuel that’s going to wash the cylinders and get pushed into the crank case. So if you’re rolling coal, you need to change your tuning, or change your injector configuration.You can't do it long on a 6.0L and maintain reliability!!! Especially if the EGR system is still "working".
A leading cause of leaks in the high pressure oil system (on the 04.5+ engines especially), is o-rings leaking. I think the MAIN root cause for that is the oil temperature. Nitrile (Buna N) is good to only 250*F. The oil temp we monitor (EOT) is IMMEDIATELY after the cooler, so we KNOW that the oil temp gets quite a bit hotter through the HPOP (heat of compression is significant). Temperature control is BIG in our engines!
Personally, I think lifter issues are related to oil viscosity and film strength (and a few others like Extreme Pressure resistance), and those are also negatively impacted by elevated oil and engine temperatures.
Also (not part of this thread), you MUST keep fuel dilution of the oil under control also for proper lubrication and protection. This is the main reason I get an oil analysis every change!
I sure loved my old 6.9L Ford!
Ahh, the good old days!!
It never got over like 190-200 even in traffic with ac on. idk it's been awhile I was really broke at that time but if you have other parts missing and extremely great condition engine it worked for me.You can't do it long on a 6.0L and maintain reliability!!! Especially if the EGR system is still "working".
I have the outer shroud still in good shape. I had removed the inner shroud because it made it impossible to change the fan belt. I have it so that the fan is shrouded all the way around, but nothing behind it. Works like a charm, and makes changing the fan belt a lot easier.Cut the jacket open on the harness and get to the wires -- make a new plug
Do you have any wire left on the fan clutch ?
make up the length needed , and add a piece of plastic tubing to keep the wires out of the fan
Fan shroud missing or broken ?
that is what controls the top of the fan harness
** if you decide to repair the harness -- be aware that the wire colors on the truck harness , and the colors on the fan harness do not match up **
you can use a connector like this
DT Series Connectors | DeutschConnector.com
Deutsch DT Series Connectors feature rectangular housing with silicone rubber seals and are rated at 13 amps continuous.www.deutschconnector.com
Indeed. And the most power loss will happen very high in the rpm range. I have a manual transmission, so I can keep rpm’s very low. Thus my power and mpg loss is basically zero.Even though the fan pulls a ton of HP it doesn't really pull that much mpg. When my fan clutch went bad it was stuck on all the time and I drove it for like a week like that and it only pulled 1-2 mpg. I removed the fan as I did not want it to blow up and take out everything. That's when I drove with no fan for 2 years. I bought a junk truck and pulled the fan off it and it's still in my truck.
