1 - 6 of 6 Posts
has any one used the fabtech 3.5 hanger/shackle lift
got some ?'s
did you use a block in the back?
how big of tires?
what else do you need?
if so some pics would be nice thanks
I have a 4.5 in the front that I will be selling soon I think it is great. It rides awesome and I could fit 37s If you want it I can get you a good deal on it. I just need to buy new stock stuff first.
PSN Regular
I will trade stock stuff plus some cash if interested..I have an o4 f350...pm me
I used the 3.5" fabtech hanger and I didn't use the rear block, I run almost 38" tires (they are narrow) and I would suggest getting the extended shocks (bilsteins) and an adjustable track bar.
I have the 3.5inch hanger and a 5 inch block in the rear. I used to have a stock 4in (measures 3 5/8") block in the rear and it sat level till I put a trailer on it, so I swapped the 5 inch block in. How level your truck will sit will depend on what front springs you have and what condition they are in.
I also have an adjustable trac bar and longer shocks.
You should be able to run 35 inch tires very easily.
Discussion Starter · #6 ·
thanks for the advise
my truck is a 2002 f250 the front seems to sag I'm running 285/70r17s with no problems
not sure if I'm going with 35's or with 295/70r17 tire next
i use the truck for work a lot and don"t want tire rub
would this lift be to much for the 33's?
1 - 6 of 6 Posts
