1 - 20 of 23 Posts
Rubber Neckin
Shop plans all finished up for the bumper my uncle and I are going to build over christmas break.
Im using the competition 4x4 heavy duty spindle
Destaco 341-r latch
I have some delrin for the swinging gate to rest on when latched into the bump stop
The latch will be positioned at an angle so it will pull back and down on the gate to prevent and movement that may fatigue the spindle
2x Rigid Dually Led lights will be mounted in the rear of the bumper
Comp 4x4 uses and sleeved spindle so you dont have to weld on the actual spindle.
Build pics and a finished product coming soon
8"x4" square tube steel bumper 3/8"
4"x3" square tube steel for the arm 3/8"
Suggestions/advice welcome!!
Rubber Neckin
STILL LEARNING
Ok. Figured it was an option. But only their SUV setup uses the hitch
sounds good, looks like ya got most of it figured out.
Rubber Neckin
heres one progress photo of the work done so far, we are building two and will have them all finished up tuesday, better pictures to come tuesday night.
Rubber Neckin
More to come Thursday hopefully have them finished! The rigid dually light just shipped today after waiting 3 1/2 weeks on backorder.
Thursday: assemble tire mount, weld on latch and hinge resting pad, rigid dualy lights
Rubber Neckin
Cool
Rubber Neckin
everything is pretty much done just have to mount the bump stop for the swing arm and mount the latch,
Made the truck mounting brackets today, and fitted it to the truck then welded the brackets solid to the bumper.
We also recessed the license plate and made cut outs to use the original plate lights from the old bumper.
Rubber Neckin
Nicely done.
where did you get the cool international badges?
Rubber Neckin
Discussion Starter #18
i got them from billet badges.com
Rubber Neckin
Discussion Starter #19
Going in for bed liner next week
Ill post up some pics of how bright the Rigid dually's are, they are flood pattern and really bright!
I'm going to be putting up a review of a 30" Rigid Light Bar shortly also, its going on top of the headache rack.
Any pics that work? Links are broken.
1 - 20 of 23 Posts
