21 - 23 of 23 Posts
PSN intsigator
They will but the dually rearends are longer and have the offset wheels where the SRW rearends are shorter. Spring perch to spring perch are the same but spring perch to hub are not
Sent from my SM-N975U using Tapatalk
Discussion Starter #22
So what problem would I have?
Looks like the truck u bought for the rear end is cab and chassis which has a narrower rear axle and narrow frame 34" best I can remember . Your truck looks to be a extended cab which has a wide frame 38" best I can remember. U will have to have a dually rear end from a dually that has a wide frame .
Springs are only 500 pound difference from f250 to 350 . If u dont have the over loads then add them .
21 - 23 of 23 Posts
