What transfer can i use in my E4OD transmision in order to convert it to 4x4 wd?
  • Any
    Votes: 0 0.0%
  • Any
    Votes: 0 0.0%
  • Any
    Votes: 0 0.0%
1 - 4 of 4 Posts
Premium Member
yes you can use those axles. but you will have to change the trans, you can not bolt a transfer case to a two wheel drive trans.
don't play well w others
Front of frame is different from 80-91, 92-97
Frame is also different as well in the front between 4x4 and 4x2.
You will have to buy or build an adapter
IOW: you'd be much better off just selling the 2WD and buying a 4WD.
  • Like
Reactions: tjctransport
1 - 4 of 4 Posts
