1 - 6 of 6 Posts
My dad is getting his powerstroke soon and wants rims, he wants these wheels. The bolt pattern is 8x170 correct? These rims would be 20x9 with zero offset. I calculated backspacing at 5'' exact and the stock 20x8 with +40mm offset at 6.07 backspacing, this means the wheels will sit out 1.07 inches more than the stock wheel correct? I dont want it to look goofy is 1 inch to much? Also the truck will be leveled to fit these wheels, A 35'' tire will fit without rubbing leveled? Although he will only be running some where around a 33.
Those rims will fit fine no rubbing with 35"s and no leveling kit
Ok. How do I figure out how much rim will sit on the outside of the hub? I know the offset is where the mounting plate is compared to the center line of the rim. Since the bmf's have a zero offset and the stockers have 40mm doesn't that mean 40mm will be added to the outside of the wheel? I am confused because the rim is 1 inch widder than stock where is the extra inch?
20x9 Novakanes, same specs as the Rehabs.. Truck is leveled with an Icon 2.5" leveling kit, and 35" Toyo MT's
Jordan. Offset is used to figure out backspacing. Once u know the back spacing of the rims then u know how much further they are going to stick out then the other rim.
Like I said 5.00" backspace is just about bang on for what your looking at.
1 - 6 of 6 Posts
