1 - 6 of 6 Posts
Ford Whore
Any of you have the Ford factory external tranny filter? I see it listed in manual about changing the fluid and filter every 30,000 miles. Just curious as to how hard it is to switch over to that system so that I can use my BG tranny flush machine.
<--Under the Knife Again
idk how hard it would be to put that system on but i have the dieselsite system on my 6spd and my fluid looks as new as when i put it in. its a very nice kit and uses top of the line baldwin filters
Has anyone gone through the process of just replacing the ext filter after getting the flush only work? How difficult was it and how much fluid did you lose?
Thanks
subscribed,also anyone have an aftermarket bypass filter added to the xmsn?
Ford Whore
I looked on my truck for the little external filter by the cooler that older super dutys have but couldn't find one. I flushed mine at 30,000 miles but I plan on dropping the pan and replacing the internal at 60,000 per the manual anyway now. Also looking into a larger pan at that time.
1 - 6 of 6 Posts
