1 - 4 of 4 Posts
ok i have an extended crank. however it only happens when im on the front tank and once it starts it runs and drives fine. my question is first has anyone come across this, and is there a pump to supply fuel to the mechanical pump on the block?
OEM Moderator
There is no intank pump if that is what you are asking. Just the one two stage pump in the valley.
yes that was the question, sorry i was rambling. ok, then what else would cause and extended crank but no running problems on the front tank only?
1 - 4 of 4 Posts
