My 2006 6.0 runs great! I bought it in 2015 with only 19,000 mile on it. It has 145,000 miles on it now. It has been studded, deleted, oil cooler upgrade, and STC tuner since 21,000 miles. I change Schaeffer Synshield oil in it every 20K to 22K miles and test the oil every change. The oil analysis is always in exceptionally good condition exhibiting at least 30% service life remaining with nearly zero wear metals. In the last year I have replaced all 4 driver side fuel injectors. Injector 6 failed a year ago and 4 failed yesterday. So today I replaced 2, 4, 8 to be done with the driver side.
I've had an ongoing oil cooler backflush regimen going for about 3 months. After the initial full cooling system chemical flush and oil cooler backflush, my ECT : EOT would stay in spec for about 200 or 300 miles and then EOT would creep up or spike. Each time I drain to flush there is more blackened sand in the coolant catch bucket. I also installed a Mishimoto w/Wix bypass filter 3 months ago. Most recently, I drove about 400 miles before the ECT : EOT got out of spec. I've been losing coolant out the degas cap and from the hose connection at the bottom. The bottle and cap are 1 year old and I finally got the hose at the bottom to stop leaking with a tighter clamp.
I did a cooling system pressure test and a block test today. The pressure test got up to 20 psi pretty quick under acceleration and the block test fluid turned from blue to green (not from blue to yellow) in about 3 minutes, and there were bubbles coming up in the block tester every few seconds. Do I have a leaky head gasket?
This truck is stupid quick on acceleration. A local performance diesel mechanic who test drove it told me it might be the quickest truck he's ever driven. At 30 to 40 mph it will spin the all terrain tires when you mash the accelerator. Is my Performance tune too hot? Might I need to o-ring the head gaskets for this tune or is that a waste of money? I've got a few more minor parts replacements to do including body bushings so if I need to do head gaskets now, I want to do all I can to be good to go for another 5 years.
Help please!
Help please!
