1 - 2 of 2 Posts
burning mine saving yours
They do not work anymore, and i'm not sure where to start(fuse, motor, etc) Anyone messed with these at all? I try to use the overhead actuator/buttons and nothing happens. Are these motors prone to going out? Can i buy replacement motors or does the whole window need to be replaced?? Thanks.
I'm not even remotely sure, but I'm sure you just change the accuator. I would first check the fuse, you can find this by looking in your owners manual and sure able to tell you where to start. If the fuse is good, then go the switches and make sure your getting power to the switches. If you are, make sure it's leaving the switch... This should give a great idea as to where your issue is.
1 - 2 of 2 Posts
