1 - 7 of 7 Posts
I cant figure it out and its killing me! after about half throttle in any gear the truck quiets out and the exaust noise cuts out and looses power. The first thing that would come to mind was either running out of fuel or oil. i put a lift pump on and did tank mods and that seemd to help alot then checkd the high pressure oil pump ICR and ICP everything was good and the really funny thing is that it has been doing it on and off ever since i had the truck ( completely stock - modded ) after i had my injectors done and got the truck back it ran amazing and heard my exaust throughout full acceleration then the truck went back to cutting out again after a week. ive sent the injectors out to be flow tested and everything and it all checks out good... im about ready to get rid of the truck
Banned
Ensure that you have at least 40psi of fuel pressure when this is happening. It sounds a lot like a fuel delivery issue.
Really sounds like a fuel pump. Find some way to monitor your fuel pressure while driving.
Village Idiot
seems like you can tap a port on the fuel filter housing , and put a guage out there for testing .
in fact didn't you (charles) run with a temporary fuel gauge out on the hood for a bit...
I know charles has lots of fuel pump failure trouble shooting expierence.
I would pick his brain some more.
Look at what your ICP does.
This can also happen if too much icp is being asked for and the pump can't keep up, PW will start falling off bad and the truck will have no power, let off the pedal and it will take off.
Any codes?
Banned
Check fuel pressure first. If this is occuring from lack of fuel pressure you're risking destroying every single P&B assembly while you're hammering them down with tons of ICP and nothing under that Plunger. Just SLAMMING them to full stroke without any lubrication between plunger and barrell. Not a good scenario.
Once you determine that you have fuel pressure, you can continue testing without fear of destroying a set of injectors.
Village Idiot
def a good idea injectors are expenssive alot harder to change then a fuel pump.
1 - 7 of 7 Posts
