1 - 6 of 6 Posts
rollin coal!
So I just installed my TS chip from PHP last week and my truck is now shifting erratically. I just installed a JW valve body last week before I put the chip in and when I ordered the chip I told them I had the VB. The truck up shifts and down shifts alot between 2nd and 3rd at about 25mph and downshifts from 4th to 3rd under a slight load when it doesnt feel like it needs to, and stays in 3rd. Its does none of this when i have the chip in the stock setting
To me it seems like when they burned the chip they didnt write the JW valve body into it...... What does everyone think???
I think you should call Bill or Cody and tell them. If it shifted ok after the VB but before the Chip it seems a bit obvious. You do not like the shift strategy. Bill and his crew I am sure will be glad to address the issue for you.
rollin coal!
Ya it shifted fine before the chip, after the VB. Its like the shift strategy is off, it will shift up and down between 2nd and 3rd over and over again
check your connections between the chip and the pcm. I have run into sim problems because of bad connections.
rollin coal!
how does it shift with the VB but no chip?
it shifted good with the VB and no chip, if i put the chip on the stock setting it shifts good
1 - 6 of 6 Posts
