1 - 2 of 2 Posts
ramblin'man
I just bought an 07 f250 6.0 crew cab with 66,000 miles. It has auto climate control. The heat works great when the outside temp is above zero but when it dips below that the air coming out of the vents suddenly goes cold. The only way to cure it is to let off the throttle and step back into it. (And that doesn't always work) The coolant is full,the engine temp runs steadily in the normal range. Any insight would be greatly appreciated.
Ramblinman
1 - 2 of 2 Posts
