1 - 8 of 8 Posts
im seeing a 14* degree diff and i just had studs, head gaskets and oil cooler done
NSTY 6OH
between 3 and 7 degrees max
6Leaker
Before the truck went under the knife for studs, oil cooler and egr delete I would see 190° out of both all day long towing or 100° days I might see 200 nut not much more. After all the work my temps vary a good bit even over the course of a day but generally they will be as follows, 185-210 for oil (gets warm on 90°+ days) and coolant will run 165-200 but usually stay within 10-15° of oil.
Administrator
Depending on outside temps ranging from 70 to 98
I see ECT 186-203 with EOT about 3-7 above after it's warmed up
ECT 194-196* EOT 200* pulling my 14k 5er add 10* to each
2 stroker
1 - 8 of 8 Posts
