1 - 3 of 3 Posts
Just as the title of my post says, my engine stumbles when running off the rear tank. I've been dealing with this issue for a little over a month now, and here's what I have observed:
- This only happens when I'm running off of the rear tank. I ran it for almost a month on the front tank with no issues. About 5 miles after I switched back to the rear tank, the problem re-appeared.
- The problem seems to occur often (but not always) when I hit a bump or have to slow down quickly.
- If I leave it in gear when the problem occurs, the engine dies. If I push in the clutch and give it about 5 seconds, the engine will rebound and I can feather the clutch and gas to get it up to normal range again.
Has anyone experienced a similar issue, or have any suggestions?
whistle tits
How much fuel is in the rear tank? Kind of seems like your pickup foot may have broken off. That is IF you have around 1/4 tank of fuel
1 - 3 of 3 Posts
