1 - 1 of 1 Posts
I have a 2002 f250 with a 7.3
I just put new seal cups and reman injectors. The reason for the work was fuel in the coolant and the truck has 285000 miles so I figured it was time. Drained all the fluids, flushed the coolant system, and replaced all the hoses. Fin ally got it to run and it has a miss. I got two trouble codes right off the bat. P0683 and P1316. Pulled the valve covers to check on the connections and wires, everything seemed fine. I started it with the valve covers off and pulled each injector wire and it made the miss worse on every cylinder. I’m going to put it back together tonight and see if anything changes. This is a Cali rig that lives in Cali. These codes are new so I’m wondering what is causing it after the work was done.
Any help would be much appreciated
1 - 1 of 1 Posts
