1 - 5 of 5 Posts
1997 F-250 HD 7.3 PSD Auto
I need help with this engine part number stamped behind oil cooler rear header.
7.4J U2U 007539 I think it`s a 94 but not sure. I have two front covers one is part #1823536C1 the other is part # 1815915C1. First one is on engine. Last person that worked on this engine was not getting oil the HPOP. LOLP gears were in backwards and I think it may have the wrong front cover installed.
Thanks for any help. Bill
See if this thread helps at all: Front cover ID guide | Ford Power Stroke Nation
I'm thinking the one on the engine is for a 97 and the second is the correct one for the engine. The position of the oil pickup is different between the 2 I think, so look out for that. Cheers!
Thanks Patrick. One more question, are all the oil pumps the same? LPOP.
I think they are the same. The only thing I've found is that they put a marking of "OUT" or "DAMPER" on the pump's face to ensure the pump is installed correctly. Not sure if the aftermarket pumps such as Melling have also done this. Cheers!
Discussion Starter · #5 ·
Thanks again Patrick
The Melling i bought is not marked so i thought i should install like it came out of te box. Bill
1 - 5 of 5 Posts
