1 - 5 of 5 Posts
I just did a egr delete with the high flow elbow. I am running sct 9625OR street tune. After installing I have a green wrench on the dash display. I know a custom tune will clear that but I have three plugs in the engine bay that are not being used, do they make covers to fill those to keep grime out of them? Also does anyone make a plug the you could put in the empty plugs to make the ECM think the valve is still there? I am going to get custom tunes but in he mean time it would be nice to fill the empy holes.
You'll need a tuner that will delete the egr/dpf. Your probably throwing a bunch of codes. It might go into limp mode after a while
they call me tater salad
im surprised it even runs without a tuner to fool the comp, it should have gone into limp mode on startup, as far as the plugs i dont believe anyone makes a cap for them i would put some shrink tube over them while the shrink tube is still hot pinch the open end to seal it off
1 - 5 of 5 Posts
