Speedometer goes off, ABS light comes on and overdrive light on the shifter flashes on and off... sometimes all 3 at once, sometimes the OD light and the speedo act up together, sometimes the ABS light comes on by itself. Then the speedo will come back on. Fuse #3 USED to blow, but it doesn't any more.
Replaced VVS sensor. No change.
None of these things cause the rig to run any differently. Batteries were not low and it's always started quickly.
Then, this morning, just walking by the rig, I hear this wierd noise coming out of it... a relay going nuts that I trace down to the f57b-14b192-aa relay in the far upper left corner of the fuse box inside the cab.
The batteries are pretty dead right now... I've got a ten amp charger on them.
Any ideas what the heck is going on here? Does the rig need a shrink?
