1 - 3 of 3 Posts
My dad and I are getting EGR deletes kits with the intake elbow for Christmas. I have read several installation instructions on the web and the all refer to torqueing certain parts to the manufacturers specs. Does anyone have the Torq specs off hand?
One is the steering shaft bolt
and the other is the exhaust manifold bolts.
Also is there anything else I should have on hand other than coolant and blue Loctite? I appreciate all of your help.
If you're planning on taking the cooler bracket off, grab some shorter bolts for the manifolds. Other than that a case of beer and a full day to do both of them. If you haven't already, adding an IC pipe should be included in your egr delete to get the most benefits.
1 - 3 of 3 Posts
