41 - 60 of 68 Posts
Discussion Starter · #41 ·
That was something I never understood, they made it sound like you had to select the camera for it to show up everytime, but your saying when the camera gets power (like a trigger from the backup lights), then the CTS will switch over to it?
That is correct.
Discussion Starter · #42 ·
Well, it's another 29 days . . . So far, so good. I haven't driven it a lot, though.
Two days from now, I take it to Tucson for someone to put it on the lift. Can't trust anyone down here in my small town. :(
  • Like
Reactions: Lt.Dan
Discussion Starter · #43 ·
So far, so good. Had a blip or two, but I will blame that on a loss of connection on a bumpy road.
Project Shamu
Sweet, the CTS3 is on my Christmas list. Hopefully Santa can pull through! Haha
Discussion Starter · #45 ·
Sorry, @Lt.Dan . . . Finally ran the wire for my backup camera today. It is supposed to show when the camera is fired up, when the backup lights are on. It worked before (I think) when I ran the wire through the window. Now I've run it properly and the backup camera comes on when I turn the key on, but then turns off after ten seconds. I don't know what is going on. I'll keep you posted.
  • Like
Reactions: Lt.Dan
Discussion Starter · #46 ·
According to the manual, the camera comes on at start up (due to the setting), and then comes on when put in reverse. It does not come on when put in reverse, even though the backup lights (from which the camera gets power) are on.
Sigh . . . . I will reset again and give it another go.
Project Shamu
Are you using the Edge camera? Or aftermarket?
Discussion Starter · #48 ·
Aftermarket. The camera works fine, as it comes on when it starts. It just does not come on and stay on when I put it in Reverse.
Project Shamu
Hmm. Edge makes their own camera that is supposed to work with the cts3, but they don't specify if you can use an aftermarket camera with it. The Edge camera is $200!!! The $25 camera i bought for my wife's truck works fantastic with her double din head unit, I would rather use that camera if I can.
Hey Jax, something a friend of mine came up with, was instead of hooking the camera up to the reverse lights, he hooked it up to a toggle switch in the dash. So he could turn it on when moving around trying to get under trailers. ( So it stays on when you pull up and move over 1/2")
Might be able to rig something like that temporary to rule out a problem with the light circuit on your truck?
Just a random thought from a nut.
Discussion Starter · #51 ·
There is a simple yellow BNC plug-in terminal on the back. You can use anything.
Yes, I will have to do something for troubleshooting.
Project Shamu
i just researched more last night. The CTS3 doesnt have the yellow BNC plug, and Edge forces you to buy an RCA to USB converter for $100 if you want to run your own camera! Wtf.
Discussion Starter · #53 ·
Well, that's bullshit. Search on line, converters are cheap.
Discussion Starter · #54 ·
Hey Jax. I have the CS2 and not a big fan. Different, obviously, but same maker. Mine never shows TC lockup, sometimes freezes, sometimes looses PIDs, etc. And heaven forbid it sits in the direct sunlight for more than a few minutes. I think it is just typical of their hardware/software. I'm about to pull mine out entirely and put it in my SSP, to probably never be seen again. I don't see anything to replace it with that would be similar in function, so I'm going to setup a laptop and run FORScan, make a mount for my laptop, and use that as my monitor. Overkill times ten, but it'll be pretty sweet I think. I will need to figure out how to monitor EGTs though, but I'll figure that out later.
Project Shamu
I dont think the OBS has a PID for TC lockup, or atleast ive never seen it on any scanner, Torque Pro, ForScan, etc? It will show gear Commanded though
I'll have to check it out. I just got my OBD-II to USB adapter yesterday and I have not had the time to play with it yet. I think it must have a PID though, it shows on the snap-on scanner that I typically use. I used it for a data run a few weeks ago and watched my TC lock up cycle on/off (one of my electrical gremlin issues).
Discussion Starter · #58 ·
Well, confirmed - the CTS2 will not display the backup camera video when in reverse. It still shows it on startup but I had turned that off -- and it still shows it on start-up. Back to Edge, again.
Discussion Starter · #59 · (Edited)
Update - the long press on the left brings up the backup camera; long press on right to go back.
I have driven over 3200 miles in two weeks. I find:
*CST2 freezes if you turn vehicle off while backup camera on. Workaround, un plug and re plug (reboot) ... or go back to main screen before you turn off.
* After the issue above, you may have problems with it reading one or more, or even all, of the gages. Reboot.
I find this unnecessarily annoying, but have not found a better answer.
Discussion Starter · #60 ·
Update, just to keep everyone informed.
I am currently driving a lot. For some inane reason, the CST2 loses a "gauge". Battery reading zero (no, it isn't, the original instrument gauge shows fine.), IPR stops, etc.
Sometimes this:
203934
And it is happening more and more. 😕
41 - 60 of 68 Posts
