1 - 8 of 8 Posts
My Edge CTS does not always come on after start-up. About 2 out of 10 times I have to unplug it and plug it back it to get it to display. Anyone have any ideas why?
Administrator
mine does it every great once in a while ,,
maybe try updating it? or call Edge they are always helpful
Check the connection on the back of the monitor.
Thanks for the suggestions.
So far I have called Edge and the tech said it might be a low voltage problem when the truck is being started causing the Edge to shut down.
I have a voltage meter feature on my radar dectector and it is running 13.7 to 14.0 volts right after start up. My batteries are only a couple of years old and it cranks over great. I will have to get the batteries tested to be sure that they are good.
I will also try tapping the screen and wiggling the connector.
Thanks Again......
Some guys on the dmax forums are having the same issue.No problems so far with mine tho.
Thanks alot! Mine did this over the weekend......
I added Fuel Pressure to mine and did an update. The update was for 03's and 04's. Mine is an 04 and so far it is fixed.
1 - 8 of 8 Posts
