1 - 1 of 1 Posts
Bird is the Word
Thursday, July 28, 2011 6:30 p.m.
$20.00 Entry Fee for all non sanctioned classes
7500# 4x4 Stock Pickup Trucks (Edgar County Only)
6500# Open 4x4 and 2x4 Gas Pickup Trucks
7500# Open 4x4 and 2x4 Gas Pickup Trucks
8000# Open Diesel Pickup Trucks
12500# Farm Stock Tractors (9 MPH)
14000# Farm Stock Tractors (9 MPH)
$10 Pit Pass (One driver will be allowed entry with pulling vehicle)
All trucks and tractors will be inspected before they are allowed to pull.
7500# 4x4 Stock Pickups
1. Edgar County Residents Only
2. Truck must be street legal (license, registration, proof of insurance etc.)
3. No front weights
4. 30” maximum hitch height
5. No solid suspension
6. No open headers
7. No traction bars
8. Must have driveshaft loops of some sort (chains, straps, etc.)
9. No diesel, gas only
10. Must have front and back bumpers
6500# & 7500# 4x4 and 2x4 Gas Trucks
1. 26” hitch height 4x4 trucks – 28” hitch height 2x4 trucks
2. DOT approved tires with 35” tall maximum. No cut tires.
3. Pull from reese type, bumper, or drawbar type hitch, with no part of hitch in front of the center of the rear axle and nothing above the top of the frame rail. Hooking point must be no less than 42” from center of the rear axle. It must be accessible and rigid. No floating hitches. Any supports from the rear of the rear axle to frame or hitch must be vertical.
4. May run front weights. No weights, brackets, or bumper to extend more than 60” from center of front axle.
5. Safety chains or loops around drive shafts.
6. Pump fuel only; no alcohol, nitrous oxide, or methane based fuels allowed.
7. Headers allowed, Open headers allowed, no side exit exhaust in front of the rear wheels.
8. Superintendents decision final and takes precedence over printed material.
8000# Open Diesel Pickups
1. 26” maximum hitch height
2. Safety chain or loop around rear driveshaft
3. No nitrous oxide or propane injection
4. Must run DOT approved tires, Duallies allowed
5. No side exit exhaust in front of rear wheels
6. Superintendents decision final and takes precedence over printed material.
12500# & 14000# Farm Stock Tractors
1. No cut tires.
2. Stock appearing fuel pump and turbo
3. No stamped wheels, cast centers only
4. 20” maximum hitch height
5. Weights must be secured
6. 9mph speed limit
7. STOCK APPEARING FARM TRACTORS (subject to inspection before and after pull by officials).
Bruce Barrett/Nathan Barrett – Superintendents
217-822-8371/217-822-8370
Friday, July 29, 2011 6:30 p.m.
$20.00 Entry fee for all non sanctioned classes
8500# Diesel Pickup Trucks
5800# Indiana Modified Tractors Pullers Association
ILLIANA PULLERS ASSOCIATION 12000# N/A Tractors
IPA 6500# Outlaw Tractors
IPA Altered Stock 4x4 Pickups
IPA Pro-Farm Stock Tractors
20000# Stock Farm Tractors
8500# Diesel Pickups
5800# Indiana Modified Tractor Pulling Association
* Must be certified IMTPA Member
IPA Classes - Sanctioned
* Must be certified IPA Member
1. No cut tires
2. No power chips
3. Stock fuel pump and turbo
4. Stock RPMs
5. 20” maximum drawbar height
6. Stock drawbar
7. Weights must be secured
8. Cannot use MFWD (if equipped)
9. No speed limit
Edgar County Fairgrounds is located in the North end of Paris Illinois on the east side of IL Rt. 1
1 - 1 of 1 Posts
