1 - 5 of 5 Posts
It's throwing the following codes
P0470 exhaust pressure sensor
P0475 exhaust pressure control valve
I have a deleted ebpv so I'd like to get rid of these codes. Will cleaning the tube do it or can I delete the sensor completely and throw a resistor somewhere... Really don't want up waste time getting that tube out if i don't have to, same with possibility of buying new sensor to clear code when it's otherwise unneeded
Sent from AutoGuide.com App
Bobs 7.3
I believe the tube and sensor is different from the ebpv in the turbo pedistal correct me if im wrong. When you delete it in the pedistal theres a sensor/resistor someone (i believe strictly diesel) sells that wont have the computer set the code for it like it would if its just unplugged.
You need a resistor/fooler from bob at Dieselorings.com
#13-023 EPV Fooler resistor
You bend this and stick this in open plug wire to remove code when scanned. Well worth the price. It works great on my truck.
Can you completely eliminate the sensor and tube with freeze plugs and still utilize the resistor to clear code?
I mean completely eliminate ebv tube and sensor with freeze plugs to eliminate the possibility of leaks and such or does your engine require those items ? Ie does the PCM need to obtain parameters for them, will I hurt anything- even the slightest decrease in mpg if I was to eliminate the tube and sensor and freeze plug both sides while also adding a resistor to that harness
1 - 5 of 5 Posts
