1 - 4 of 4 Posts
I was tld to elimnate the problem of my ebpv valve gettin stuck and makin that woosh sound when the air gets stuck i could take off something off the bottom of the turbo? COuld anyone tell me where this is located and how to take it off and fix this damn back pressur problem. thank you.:ford:
Premium Member
you will see a rod coming off the passenger side of the turbo pedistal, thats the rod that moves the valve.
an easy way to gut it is to unhook the down pipe from the exhaust side of the turbo, then un bolt the ebpv part from the turbo. remove the valve from there and use a preeze plug to fill in the hole.
ok thanks for the help rob why does the ebpv stick?
1 - 4 of 4 Posts
