1 - 6 of 6 Posts
STILL LEARNING
I did away with my EBPV and solenoid. Is this going to set a code? Motor is out of the truck now. BTW this in in my E99.
Just wondering if I can but connector the 2 wires together, or tape the connector back, or what to do with it
Try a 470 ohm 1/2 watt resistor in the plug,works sometimes and its cheap...radio shack
STILL LEARNING
What is a soft code? will that not set a check engine light? If not then I dont care, but if it will
Well the harness is kinda F-d up from a mouse or something If i just cut a and slice it together with a resistor, will that be ok?
Mine set a cel 0478 iirc yes just splice the resistor inline
Soft codes dont set the Check Engine light, but when you scan your truck they show up on the read-out
1 - 6 of 6 Posts
