1 - 5 of 5 Posts
Ive tried searching the forum and the internet and I cant seem to find what the normal ebp should be.. Also when one refers to wot does that mean the reading should be taken with the go pedal to the floor any help would be appreciated right now running 70mph on a flat road Im hitting almost 30 for ebp just seems a little high to me truck is all stock except for whats needed to make it reliable dummy plugs stc things of that nature I am running the street tune from sct
Premium Member
At idle I see 2-3PSI, mostly 2PSI for EBP. You need to understand how your monitoring device reads pressure. Some will include atmospheric into the value, so you could see 16+PSI at idle. Look at the following: BARO, MAP, BOOST, EBP and you will see what I'm discussing.
1 - 5 of 5 Posts
