1 - 3 of 3 Posts
Good morning. I have been driving with the sct x4 as a monitor for a day and the only negative I got was the ebp sensor stuck at 43v. I disconnected it and the number went up to 80 and then floating ed around 78 or so. This obviously left the vgt up at 84 for until I plugged the sensor back in. It seems that the Vgt hangs around .55-80 normally. It was nice to see the immediate reaction when I disconnected the ebp sensor. Im hoping that fixing ebp fixes vgt range. The Turbo is clean.
When I get home from work today I’m disconnecting sensor and attempting to clean the tube going to the header. Is there anything else that I should be doing while I’m at it? Thanks in advance.
Update. Cleaned tube and Replaced sensor. Vgt and ebp readings now change together. Thanks everyone!!!!!
Sent from my iPad using Tapatalk
1 - 3 of 3 Posts
