I am selling some parts off a early 99 power stroke motor that dropped a cylinder. Motor sat after being pulled for a couple of years. Assuming everything was good when pulled but can't promise anything now as I don't have a 99 model truck to test anything on.
shipping is from 37128. I prefer to use UPS ground as the customer counter is next door to where I work.
Alternator $65 includes pulley
water pump (yeah I know, who buys a used water pump? you do if you got $25!) does not include pulley $25
power steering pump $20 with reservoir no cap though.
one valve cover gasket with wiring harnesses, appear good $75 this is the "one plug" style I can't reuse on the 97s
engine harness $300
fan $25
turbocharger and pedestal $200 - early 99, this may not be the same as '99.5-'03, I'm an OBS man so I don't know.
intercooler with plastic ends $100 needs cleaning inside, it is full of oil from blowby from the bad cyl. It has run most of it out in my shop floor
5 gal of kerosene and you should be good to go. This motor was pulled from a rollover and ran several years in my buddy's 2002 so that's why the plastic ends on the IC.
intercooler pipes with boots and 4 of 8 factory clamps $50 (they're full of oil too)
intercooler spider - THIS IS "THE ONE" THAT FITS THE OLD BODY STYLE - with reducer boots and all 4 hose clamps $175 I do NOT have the v-band clamp to fit the turbo. reducer boots fit the 2" intakes on old body style 7.3 powerstrokes
will sell the whole IC setup for $300 boots clamps spyder pipes and intercooler (save you $25!)
HPOP $200 this is the 15 degree one - has a flat back (this is Early 99 remember)
fuel bowl and hard fuel lines $100
I can email pictures. pm me with your email address. cash offers talk too. Stuff is located in Murfreesboro TN, 15 miles from Swamps and 1.5 miles from Full Force Diesel.
engine harness $300
fan $25
