1 - 6 of 6 Posts
My early 99 has an oil leak that I cannot chase down. It is covering the serpentine belt and causing it to slip(2nd belt in 2 months.) Along with coating the entire front of the motor on the drivers side. any ideas?!?
The Oracle
Off hand, front seal maybe. You really have to clean the motor thoroughly and then run it and look for the leak
Possibly the cover for the hpop gear bolt.
Village Idiot
If it is not the seal...
Def oil not waterpump or tstat housing right...they go badafter ten years or so.
Still the original hpop, no swaping to a 17 and using wrong gasket etc.. That can crack the case, though not sure where that leaks., hpop lines can leak and spray too
1 - 6 of 6 Posts
