1 - 1 of 1 Posts
Hey guys I have an early 04 6.0. I have the egr delete done, blue spring kit, also recently replaced the number five injector, installed sct livewire, new hpop as of a couple months ago. Ever since the hpop my truck has steadily ran worse. It starts every time but starts up real slow. I constantly have 48 volts to the ficm. The truck will run smooth then randomly start missing. While driving it will chug until oil temp is at 190. The truck will de fuel randomly and start turbo bar king bad when I let off the throttle. Truck is also shifting at higher rpms and rough. I have not thrown a single code. If I rev my truck up and let it idle back down it will almost stall. The same goes if I go from drive to reverse. Any help would be greatly appreciated. I don't know if it could be a sump or an issue in the fuel system
1 - 1 of 1 Posts
