1 - 4 of 4 Posts
Carolina Gray Boy
I’m needing to change my front rotors, pads, and calipers. I’m wanting to upgrade my brakes while I’m doing it. I’m not sure if aftermarket rotors are better than OEM rotors, I’m looking at Hawk pads, and I’m not sure on which caliper would be best or just buy OEM calipers. I do tow a 35ft fifth when and a 23ft CC boat.
Bent70
I did hawk sd pads and powerstop rotors i believe. Great improvement on stock pads and rotors. Then did a 06 axle swap and the oe brakes are much better than the upgraded 99 brakes
Carolina Gray Boy
Which power stop rotors?
Carolina Gray Boy
Ok I’m set on my calipers I just need front n back rotors. I have looked at raybestos towing off rock auto. Any know if they are any good? I’m not looking for slotted n cross drilled. I’m more interested in solid rotors. I’m also wanting to order off rock auto. Please help I need to do brakes ASAP.
1 - 4 of 4 Posts
