1 - 5 of 5 Posts
what is the difference between a 10 and 13mm hub flange? what one does my e99 have? anyway to tell & what exactly does 10/13 hub flange reference to?
TennesseeHillbilly
early 99 is 10MM
Need more power!!
What's the difference?
TennesseeHillbilly
ford increased the mounting flange thickness appaently for greater strength, the rotor offset is different to accomodate the thicker flange. they will not interchange. the good news is, you can run the later model stuff on the early model. just be sure you get the correct rotors if you change to the later model unit bearings.
1 - 5 of 5 Posts
