Rebuilt the trans myself. BUT i forgot to flush out the cooler.:doh: Sooo. The trash wound up in the pump and the OD piston on the valve body. I dropped the pan and cleaned the valve bodies enough times to go through 5 gallons of tranny fluid. I eventually just said screw it and drove it with the OD light flashing and no OD. So a year later i got time to tear it down and this is what i got. Looks nice. Everything above the mid support is trash. Reverse, and intermediate bands look new, as well as the clutch band. You can see that heat killed alot of parts. The top plate for the OD clutch pack warped bad and welded a few clutches to it. I need to find a new case too because i have alot of valve body bolts that stripped. OH well. enjoy the pics.
