1 - 6 of 6 Posts
97 f350 7.3l 4x4
Transmission was stuck in first so i rebuilt it. Shift kit, new solenoid pack, all new clutches, new TC ect. Still the same issue.
No overdrive light and button doesnt do anything.
I was messing around with the tailights and washed it underneath put a tuner in it right before it happened. My tuner or obdII scanner wont pull codes and not sure how
Former Ford Trans Engr.
You problem is electronic, not in the transmission. But you already knew that from the rebuilt trans still not working.
You MUST get the codes. If your equipment won't do it, either get something that will or pay someone to read the codes. Any good independent shop can do it, and so can a Ford dealer.
Mark, should he be able to force a 1-2 shift with the column shifter?
Does the trans shift 1-2 manually?
Yes, he should be able to force a 1-2 with the shift handle.
1 - 6 of 6 Posts
