Hello all, first post here. I've done a ZF5 swap from a donor truck and was able to swap everything over except the steering column, it was to far gone so I pulled the column to make it easier for my pedal assemble to go in and work and then when I went to replace it I removed the auto guts from the steering column. Now I'm trying to get the truck started to do a test and the dang thing won't unlock. The key will not turn now, it's like the steering wheel is locked but I've tried everything to unlock it. Here is a few things...
I've got the manual harness hooked up but the pigtail for the reverse lights on the transmission was broke off so I have to replace it therefore the harness isn't plugged in to anything technically but it only plugs into the tranny for the reverse light and transfer case so shouldn't be an issue especially with steering wheel lock.
My thoughts are something still thinks the truck is in drive instead of park but I'm not sure how.
Hope you all can help I'm so close I can taste it.
