1 - 8 of 8 Posts
when i go about 20 miles and stop at a stop sign or what not and go again, i have to get it up to about 2500 rpm and let off of it and get back in the throttle for it to shift. anyone else have had this problem and what do i need to do to fix it?? thanks
Demon Dually
Does the overdrive light flash on the shifter? I would check your fluid level color and smell first. If it is dark in color or metallic colored or smells burnt your converter or trans are on the way south. The stock converters are known to give out and smoke the trans with them. The solenoid packs also go bad often. If the light is flashing then you need to get it scanned. The part store scanners do not work on our trucks. You need to find someone with a high end scanner like a snapon, Auto Enginuity, etc.. or take it to a shop that can scan it.
i have not seen the OD light flash. i will check the trans fluid in the morning. but i can smell a burnung smell when i drive it on long trips and stuff. i think ill git my teeth and buy a new trans as much as i hate too. but if it needs one it will be best to buy a new one.
Demon Dually
Well I would check all the things I mentioned first before buying a new trans. If you are just low on fluid it would be a bad decision to put a new trans in don't you think. On the issue of a new trans though, the best ones on the market are the BTS from Brians truck shop and John Woods. I have a pretty stout trans that I bought from an unknown shop in Florida that is an up and coming facility that is taking everything I can put at it without a hitch(knocks on wood). It all depends on how much you want to spend and what all you plan on doing to your truck performance wise.
yeah im gonna check out everything first before i just go out and get a new one. and i have heard some good things about those BTS trans. the only thing i have planned for the truck performance wise is to get a cold air intake and a chip. i just put an exhaust on it so im good there. you know of any good chips or programmers for a decent price our trucks??
Premium Member
this quote should help you on the chip side of things.
Some quiet reading for you to research chips and what will work best FOR YOU and YOUR GOALS.
As for tuners versus chips Tunes you can not switch tunes on the fly you also will be limited to generic tunes or only one maybe two custom tuners and then you will be very limited in your choice again. In just about every way the chip is better choice. One thing that can be of confusion on here if you are somewhat new is the use of the term "tuner". On here we are almost never referring to the device called a "tuner" but the person that actually is writing the tunes themselves for the chips.
I would say, easily, 99%+ of members on here and most other dedicated 7.3 sites use a chip not a tuner.
One other thing to keep in mind: the maker of the popular chip used by many tuners to installed there tunes on is the "TS chip" )6 position chip). But that same manf also sell that chip with generic tunes directly to the public as well. So you will see comments about "TS style chips" from one of the custom tuners you are about to learn about with some reading. You want the ones from the custom tuners not the generic TS chip and tunes directly from TS or others. You will quickly understand the difference with some reading.
Of the various custom tuners out there these are the poplar ones with the best reps. Read the thread links below to learn more about them to help you make your choice:
Custom Tuners:
Swamps (Jonathan)
Gearhead Automotive (Matt)
Beans (Jonathan)
BTS (Cale)
Power Hungry Performance (Bill)
Diesel Innovations (David)
Total Diesel Performance(Tony TW)
Truck Source Diesel
DP Tuner(Jody)
Most every question you can have about chips the tuners who's tunes are run on them should be answered in the threads linked below. Including which is best, this tuner versus that, this chip versus that, etc... If not ask and I am sure you will get answers.
Superchips 1805 vs Custom Chip ? - Powerstroke Nation
Chip vs Programmer - Powerstroke Nation
programmer for an early 99 - Powerstroke Nation
Dp Tuner vs. TS performance - Powerstroke Nation
Custom tuning choices???? - Powerstroke Nation
Diffrent chips - Powerstroke Nation
New Beans Tunes! - Powerstroke Nation
ts 6 pos chip? - Powerstroke Nation
After all this... A Cracked Block. - Powerstroke Nation
Chips anyone? - Powerstroke Nation
best tuner/chip for 02 7.3? - Powerstroke Nation
chip AND programmer??? - Powerstroke Nation
Adrenaline w/ Dp tuner - Powerstroke Nation
Need some opinions - Powerstroke Nation
Another chip question... - Powerstroke Nation
Chips??????? - Powerstroke Nation
looking into getting a TS chip - Powerstroke Nation
What are your thoughts on Powerhungryperformance chips - Powerstroke Nation
Looking for a new chip - Powerstroke Nation
Ts, Dp, or Tw - Powerstroke Nation
Piston Star Patterns - continued - Discuss - Powerstroke Nation
Safest Tuner ?? - Powerstroke Nation
looking for another progammer - Powerstroke Nation
STACKING TUNERS CAN YOU GUYS EXPLAIN - Powerstroke Nation
Recommendations on Tuners - Powerstroke Nation
Are flip-chips harmful to PCM's? - Powerstroke Nation
99.5 wanting to get a chip - Powerstroke Nation
PHP tuner and the fun times you can have with it! - Powerstroke Nation
High miles and new chip? - Powerstroke Nation
DpTuner - Powerstroke Nation
chip questions - Powerstroke Nation
TW tuning ? - Powerstroke Nation
more power? - Powerstroke Nation
Need more Powa! - Powerstroke Nation
TS CHIP TUNES - Powerstroke Nation
Empire tunes? - Powerstroke Nation
just got my new tuner have a question??? - Powerstroke Nation
bdp custom 7.3 tuning - Powerstroke Nation
chip installation - Powerstroke Nation
Tony Wildman Tunes - Powerstroke Nation
Best Tuner - Powerstroke Nation
TUNING - Powerstroke Nation
so its time for tunes - Powerstroke Nation
Gearhead Automotive Performance Customers! - Powerstroke Nation
pricing out a chip and have some ?'s - Powerstroke Nation
thanks for the info on the chips and programmers. Ill look into the TS chips i have heard that they are a pretty good chip.
1 - 8 of 8 Posts
