1 - 9 of 9 Posts
<--before leveler & block
3 runs everything in my signature and hit 491hp and 836tq and i backed out of it at 3100 with an end rpm of 3186.....is the dyno messed up? Also, i have my wastegate set at about 33psi.
That seems like solid numbers for your setup.
Forgot to mention, first two runs were to 3k rpm's and the last one was up to 3186. Thats why there is a large variation in numbers. And no those are not low numbers. I was thinking they are at least 50hp high for my setup.
6 speed manual......track times would be slower than most trucks though
Edward Scissorhand WanaB
Maybe Swamps sent you a set of 238/100 injectors instead of 200/30 injectors. Those #'s do seem high for 200/30 injectors but hey it is what it is. Good job and great #'s. When I dynoed my 200/30 injectors with Swamps tunes and live tunes from Jody at DP my Swamps tunes only got me to 350 hp and DP tunes got me to 419 hp. Same dyno, same day with back to back runs just a switch in chip and tunes and it pulled off a 419hp and 858 tq.
I'm sure Jonathon could have done some adjusting to my tunes but I never got around to sending my chip back.
I just found out that there was a correction factor which puts me at ~415ish hp and 836tq at ~5500feet
Ah, Ha, Now you are right in line for what a 200/30 injector can do. Still good numbers anyway. I buddy of mine has a 2001 automatic transmission and a Turbonetics Ball Bearing Turbo and Stealth Stage II and did 417hp with 200/30 injectors.
1 - 9 of 9 Posts
