1 - 20 of 67 Posts
I know nothing...
Just like it says, anybody know?
I don't think you're going to see huge gains with such a small capacity injector. But I'm sure you'll get a little.
90ccs man.. its like trying to shoot water through the barrel of a handheld squirtgun with a hi-vol pressure washer........
got fuel?
They only needed the 15* oil pump to run those 90cc injectors :poke:
I wonder if the same question was posed, but about AD's, what would the answer be? Has anyone actually done a before and after with AD's to see a real HP gain?
I know nothing...
Discussion Starter · #8 ·
I think that's how arisely is rolling, don't know if he's dynoed it.
I got AD's in my OBS and when I switched from the 15* hpop to the adrenanline man it was like a new set of injectors in again!:evil
O HP gain with stock 90cc inj's. Don't care what pump is used.
Yeah, the only way I could understand a change would be with tuning changes and some would have to have been left on the table in the first placed.
I know nothing...
Discussion Starter · #13 ·
So how's about some hard #'s for the SD with tunes and AD? Or has that been posted already?
:popcorn: getting a adrenaline next weekend with minor mods, keep er commin. mind you i am getting ready for stg 2s. ive read so many testicimonials on dieselsite about people with completely stock trucks having huge seat of the pants diff. just read here, 1994-2003 7.3L Dieselsite Adrenaline HPOP is this a crock or should i do this?
I'm one of those "seat-o-the-pants" guys on Dieselsite's Adrenaline section. I can not keep my Autoenginuity connected long enough to get good numbers. Chris and Brad(also in the Adrenaline section) have some good before and after numbers. I don't believe a stock truck will see much hp increase but you will feel the difference over your stock unit when accelerating and towing. Just my 2 cents!
I don`t have any dyno numbers but on my early 99 the Adrenaline made a huge difference from 2000 rpm til redline. That is with the stock ab injectors. I was planning on data logging before and after and a video of truck going through the gears both ways. I think the hard drive is out of my laptop so I might have lost my "before" data. I plan on taking my hard drive to see if anything can be retrieved so hopefully I still can.
Drive fast, look cool
I put it on mine with stock sticks and superchip 1705 programmer. There was a huge difference. My truck pulled hard all the way through the rpms with a low end grunt I had never felt. I'm now going to bigger injectors yet again and now have a 6-pos chip too. You will notice a difference with stock injectors.
I have a write up on it on powerstroke.org
Pulling sled for hire
A lot of that is probably going to depend on the condition of your stock pump. If it's worn and getting weak, then sure you'll notice a big difference. If your pump is healthy though it's going to be tough to starve it for oil with the stock injectors.
True, I did not mention that. Possibly my pump was not 100% when I bought the truck. I damn sure noticed a difference lol... Thanks!
I know nothing...
Discussion Starter · #20 ·
I've been in the archives trying to absorb as much knowledge on inj's and what makes them work. If I am understanding correctly the stock inj will not bet able to take advantage of the extra volume of oil but...
The added psi should make the injs perform better especialy @ high rpm given the quickend cycle at which they aredischarged though the filling is still dependant on the lift pump.
Do I have this right?
If so the answer should be "yes" the ad will be worth something but not much until more vol inj's are added.
1 - 20 of 67 Posts
