I have an 03 f250 6.0, i am wandering if i can put double shocks up front and in the rear just by using a grade 8 bolt that is long enough to bolt one shock on either side of original mounting position? Front and Rear? and if its worth puttin 2 es9000's or just using 1 bilenstien 5125? I should also tell you im running a 6.5 inch lift with 38x13.50x18 toyo m/t's
