1 - 7 of 7 Posts
I when i purchased my truck i was told it needed a clutch, so i bought the conversion kit to a regular fly wheel.
When i dropped my tranny i realized the clutch, and flywheel were in good shape, the through out bearing went out and caused damage to the pressure plate.
I had already purchased my new flywheel/ clutch kit so i went ahead and installed it.
Is my dual mass flywheel worth anything to anyone?
Demon Dually
Scrap steel??:poke:
could make a nice john boat anchor
That is exactly what i was thinking but i did not want to chunk it and it be of some value to someone else.
ah all psd guys need to convert to single mass, so one less dual mass is ok ;)
I'm wondering if I could make mine into an isolation pad for my stereo turntable, after I press off the ring gear and take the center section out.
That's the only use I've thought of so far!
Fixing Broken Stuff
In my area it worth about $220 a ton or .11 per pound. Well if its good you could ebay it, somebody someware wants it
1 - 7 of 7 Posts
