1 - 2 of 2 Posts
· Registered
Just replaced my fuel bowl and snapped off the fpr housing in the nut of the fuel line. While trying to remove the broken piece I ended up crimping my fuel line. I already purchased the new lines. Just wondering if anyone has done this before and can give me some tips and advice on how to go about getting it done the best way possible. Thanks!
· Registered
2002 F450 SD 7.3L 4R100 RWD DRW
The fpr housings/kits are readily available as I'm sure you've seen. As far as the lines go, you will just have to move what you need to "get-er-done". But don't be fooled by the one spot on one of the lines that looks crimped. You may be seeing the spot that is normally flatter looking and think you did it yourself. Mine is like that too and had me scratching my head, but I've seen many engine bay pics that confirm this is just the way they look. However if you actually destroyed it with pliers or something then yes, replace.
1 - 2 of 2 Posts
