1 - 6 of 6 Posts
Hey guys just a quick question seeing if anybody has run into these same issue. I recently returned my truck to stock 2013 F250 6.7. After removing my H&S xrt pro my truck keeps setting a P160A. Truck was deleted btw. I've reflashed PCM with IDS, did an as built reprogram also, nothing seems to fix it. Need help trading truck in, have left H&S a few messagesno but no returned calls. Any help would be great. Thanks
P160A Engine control module (ECM) - activation error -
There's a parameter you have to reset with the IDS and it will clear everything learned in the past including that code.
Can you tell me how you got rid of that error code above? you said you have to a parameter with the IDS and that will clear everything. I had the same thing just happen when uninstalling my XRT Pro.
I too would like to know the parameter you did to your IDS to get it to clear and reset everything.I have a SCT Livewire ts+
1 - 6 of 6 Posts
