1 - 6 of 6 Posts
Has any one put a drop steering/pitman arm on after the rsk swap. Mine has a little bump steer and I think this will fix it if it isnt too hard on the gearbox
mine bump steers alot after the rsk especialy compared to my stock 97 350
I put one on, and don't have bump steer... but I do have steering wander.
Not sure which is worse! One of these days, I'll put the stock arm back on to see if it makes a difference.
STILL LEARNING
On my 1st RSK i did a drop pitman arm. But on the last 2 I have not and they are fine. Even though I have sloppy steering in my 97
ate lug
I ran mine with the drop pitam arm for years. Had a little bit of bump to it, but it really wasnt that bad. The biggest issue is the crappy stock steering. I switched to a high-steer setup back in march/april with a stock pitman arm, and the difference is amazing.
1 - 6 of 6 Posts
