1 - 12 of 12 Posts
Anyone upgrade their drive shaft to a 1 piece unit? Also what is out there for beefier U-joints?
Thanks
<--Under the Knife Again
I have Spicer High performance u joints in mine from theujointstore.com i would like to see a one piece made up id buy it.
WWDD
my plan was to take them to a local drive shaft guy and have them re-tubed with heavier wall tubing and maybe upgrade the u-joints, its not going to be cheap though
Im not sure how important all of the this is, some people have said they have seen multiple driveline failures, when i think rudy is still on the stock drive shafts :shrug: but i think sled pulling is where people are twisting the tubes into candy canes
My u-joints and drive shaft have 75,000 miles on them and no issues yet. I have only pulled a sled twice, but I do plan on pulling again in April and May, so we shall see what happens. I know boosted launches have got to be hard them....I have done quite a few of those lol
Laces Out
any quality driveline shop can make you a good 1 piece. but dont plan on adjusting the height much. i plan on doing this once i drop the truck another inch.
The issue with a one piece driveshaft is overall length. The limit is the CC/SB for one piece shaft, if you have CC/LB it won't work. Many driveshaft shows don't even like building a one piece it the length required for a CC/SB due to the weight of the tubing required for the proper tube strength. It does work, my 7.3 CC/SB has one, Aaron's CC/SB has one(he was racing that truck 1st), and we've done many customers trucks that way.
The shop that built my one piece told me my truck was almost to long for a one piece, but I don't have a t-case to make up the difference from a extcab to a crewcab. Because it is lowered I can't fit a 4" shaft like I wanted and had to do a 3.5". The shaft shop expressed their concern with a 3.5" and the length, with the power I am making. Ideally a 4" is the way to go.
Also, if I don't break a stock shaft then I can't see anyone else......... that isn't sled pulling. Even after my pumpkin got turned up, I could have reused my stock shaft with new u-joints. Unless you like to spend money or broke the stocker, I wouldn't be wasting my money on a one piece.
1 - 12 of 12 Posts
